Re: P0341 Camshaft postition sensor bad?
hpmotors
While it wasn't the camshaft code, apparently my problem seems more common as I had a bad Crankshaft Position Sensor (CPS) code. Finally got it out - rather pissy to get at. Not sure if my fingers are too fat, too short, etc. but I couldn't get the electrical connector loose without removing the small heat shield. With the shield in place, I couldn't get to the CPS and exert enough force to release the connector. Once I got that thing off, I could grip the connector with enough force to release it. Rest of removal was straight forward per the link. Other slight difference was I didn't need a flex joint to get at the small bolt that holds on the CPS, just a short extension and 1/4 drive ratchet.
Question is what is the best source for this thing? The MB part is made by Bosch. Who makes the sensors from the Advance/AutoZone/NAPA's of the world? Is it worth while to get an OEM part?
Where ever I have to get it, sure hope that it is the culprit. Car has cut off twicet now galdarnit. Really annoying in the extreme.
The motto is 'Go Bosch or go (walk) home'.
Bosch Item Number: 0 261 210 170 - Also Replaces 0 261 210 171
Mercedes Benz #: 003 153 27 28 - Also Replaces 003 153 28 28
https://www.germanautosupply.com/sto...sensor-82.html
