Thread: Sub help.
Old Nov 13, 2012 | 02:56 PM
Selbyl's Avatar
Selbyl
Default Re: Sub help.
There are kicker 6.5" sub that fit, not sure on the wattage but you can mount the amp you need under the carpet where the tire repair kit is and run the wires to the speakers behind the seats underneath the carpet. I have two amps under there and there is more than enough ventilation to keep them cool.
Originally Posted by stryfox
Ok, here is the plan.
I have an aftermarket head unit I like installed. It is wired to the factory amp.
I hate not having separate sub control.
I was thinking about removing the factory subs and replacing them with something better that can be made to fit in the stock location.
I want to add an amp just for the subs so I can use the aftermarket head units sub control.
I plan on leaving the door speakers hooked to the factory amp.
Any ideas on what subs are good that could fit?
Also any reccomendations for a good amp to power just those subs?
Thanks
