Old Nov 24, 2012 | 05:55 PM
onehundred80
Default Re: New battery installed and...
Originally Posted by paandnana
Water was in the well cavity. Drained water and used hose pipe to find leak. None found. I think it was probably a leak in the back window before the new top was put on in August. Installed part, Central Locking Pump module and everythng works except for the high beam headlights.Thank you for your help and also for saving me a lot of money!!.
On the MB forums it is suggested that the pump module be placed in a plastic bag, or the plug in the floor pan is left out.
The extreme measure suggested is to put the pump in upside down if the cables allow it.
That's why Australians never have this problem.
