Old Nov 25, 2012 | 04:05 PM
Infinity's Avatar
Infinity
Default Re: Cats making noise - Fronts this time
Originally Posted by dinasrt
I have not done a cat replacement yet. In my conversation w/ Rob @Needswings, he suggested to me that when I do the exhaust Mod that I want to do, to use the fully metallic high flow cats vs. the ceramic, because of the very problem that you are experiencing. Apparently the ceramic cores just don't hold up to our output. Here is what I am looking at:
Vibrant Performance ::.
Not sure if this helps you or not, good luck.
Not sure that HP in this case is responsible fo rthe cat issues. High milage is one reason for the breakdown, and MB had a history with this engine of failures in the past with the NA version of the motor in several vehicles. Generally the metallic are going to be less expensive so that would be a good option, especially given the milage, but the car is in such great shape and motor is clean as a whistle so I see my ownership lasting a long time.
I wonder if anyone has the flow specs from the oem to be able to find a match?
