Here is the pump as delivered, my series 90 pump for your enjoyment. I have a motor speed control on order so that this can be controlled for daily or high power operation depending on the setting. I will be doing testing with hot water to show the relative gain of parallel water flow versus stock 3 pass 'series' water circuiting provide. Its bigger and will require some planning to install in the car neatly.
Hope the holiday was good to all of you - I drove N.C. to V.A. for 600 miles and found the roads mostly passable. Woody
Its also mag drive and same 5000 hour life rated.
http://www.pumpvendor.com/Johnson_10-24664-01.html
