Old Nov 29, 2012 | 02:27 PM
onehundred80
Default Re: Wheel Bearings gone bad on any one?
Originally Posted by psuperti
I got the front tire noise too! The Nitto Invos stock size are almost done at the outiside cornering points from a small negative aligment. Anyways I can hear the car rolling, it does not sound mechanicaly bad its just road noise and maybe the bearings rolling motion (small dragging noise?). Its not worse during braking. I got two new Nitto NeoGen to put on this week or so and they will match the back tires. My milieage is 45k on the 2004 limited with Stern wheels. Tire or Bearings? Thx!
discount tire direct Nitto Neogen 225/40/18 I think was $118 each
I'd bet tire noise, my old front Michelin AS tires took on a wear pattern which had each block of tread worn down more at the back of each block, like a saw tooth pattern. At about 20mph it was heard as a bearing type noise, above that speed I guess it was one roar. New tires fitted and the noise was gone.
