Old Nov 30, 2012 | 06:54 PM
Mrmiata's Avatar
Mrmiata
Default Re: Turbo-New ideas & input
The Kleeman SC that was out for the NA didn't state any additional engine components to handle the near 7 psi boost. I'd say the "stock" setup will sufice if this is as far as you take it. Might want to see if you can pull up some archive files somewhere on an install. I'm sure it would give you a good clue on fuel pump and injectors too.
