Re: electric supercharger
If you use a starter solenoid you won't need a 60 amp switch. Also the longer the wire run the larger the wire must be going to the motors. If you use 4 gauge wire you will only have to run one wire to the motors. Put a good ground at the batteries and at the motors.
