Old Dec 5, 2012 | 04:05 PM
Airscape's Avatar
Airscape
Default Re: Thinking about new wheels, thoughts, opinions, suggestions?
TSW and all of the million rebranded TSWs are good options to sift through because of the offsets and 18/19 availability. JHM did all the grunt work on the wilhelms, I just copied but I would recommend them. The only real negative is the weight, for being bigger than the stockers they are basically the same once mounted up. If they had the same style/sizes but lighter I would jump right on em right away.
If you have any good wheel shops local (specially high end) you can try stopping by and giving them all the measurements you are looking for. They can do some homework for you and can usually find some options you wouldn't see otherwise.
