Re: No camber??
Fastfred; was your car subject to an impact to the front wheels? The collision repair adjustable camber bolts are only good to + or - .5 degrees from what I've been told here on the Forum. I'm thinking you should get a second opinion on the alignment figures. If they're the same as the original shops diagnosis, then the collision repair bolts won't get you to spec.. You'll need to go with a more expensive fix.
