flawxy
thank you thats what i was looking for. is it easier to use the 2 wire terminals so i don't have to figure out what to do with that second wire on the spade terminal? maybe ill do one factory horn and replace the other with the wolo
You will still blow the fuse (#6 fuse in the box next to the battery). If you're going to use that new horn you will need to wire in a new circuit. The second set of OEM connectors is for the second OEM horn . . .one positive wire (the brown with the black stripe and one negative wire the brown wire). You don't have to use that second set of connectors if you are only hooking up one horn . . . but . . . you won't be able to hook up the new horn to either of the OEM connector set of wires without blowing the fuse.
