Old Dec 11, 2012 | 06:20 PM
ala_xfire
Default Re: Camshaft sensor, Crankshaft sensor and MAF later... still problems
Originally Posted by maxime75us
Thanks 180
Here are the remaining code
P0300
P0301
PO302
Po303
Ignition system Fault spark plug
Vaccum leak
injector fault
High or low pressure
Car is difficult to start...a pain
Not full power ( of course) when i drive it
I did change the Crankshaft/Camshaft sensor and the MAF
Please advise. Thank You...A lot
Max
All the codes you listed are spark plug missfire codes :
(P0300) MULTIPLE CYLINDER MISFIRE . . . . . . .9-283
(P0301) CYLINDER #1 MISFIRE . . . . . . . . . . . .9-294
(P0302) CYLINDER #2 MISFIRE . . . . . . . . . . . .9-304
(P0303) CYLINDER #3 MISFIRE . . . . . . . . . . . .9-308
(P0304) CYLINDER #4 MISFIRE . . . . . . . . . . . .9-312
(P0305) CYLINDER #5 MISFIRE . . . . . . . . . . . .9-316
(P0306) CYLINDER #6 MISFIRE . . . . . . . . . . . .9-320
where did you get the other fault descriptions ?
As to the P0300-P0306, this would be my approach :
1. do the easy stuff first - swap the coil packs left to right, reset the codes and see if they change with the coil packs.
2. If not, then replace all the plugs and plug wires. ( complete kit available at NeedsWings for $200 )
