Old Dec 23, 2012 | 02:45 PM
67wildbill's Avatar
67wildbill
Default Re: Rear camber/tire wear advice
ok thanks.but you could use the steel swedged tubes and not have to cut them or do any tapping or threading.that's what i'm getting at.on ROD END SUPPLY they have a chart for getting the right length on the tubes.they say for 5/8 rod ends you take centerline to centerline measurement and deduct 3 inches for the size of the tube.when i measured the arms they measured 11 3/4.that should call for an 8 3/4 in rod.so i guess a 9 in tube would be the one to use.then when you put the rod end on you would have plenty of adjustment.
