Old Dec 24, 2012 | 06:29 PM
bikerlifeetc@hotmail.com's Avatar
Default Re: dome light sensors
Without some computer skills you are at a real disadvantage I'm sorry to say.
Try and download this link and save it to your desktop.
2004 Service Manual (click)
It is a big file and takes some time to down load.
Open it from the desktop and go to Section 23 page 35.
It shows the latch and the harness connection, it is possible that it was not connected at all when it was being fixed.
The harness is inside the hatch door and is accessible by removing the interior trim panel.
There is nothing to adjust, it works or it does not work.
thanx for the link to the service manual. I will save it to my desktop as suggested. I have fixed the dome light! As it turns out, that switch is in the latch assembly itself, if your body striker hoop is not adjusted high enuff, your latch on your liftgate will not push all the way up into the second notch on your liftgate latch, and your light WILL NOT go out. As soon as i adjusted it, it worked flawlessly! Thanx all!
