JimmyJames
Master Cylinder---"the master cylinder is full of burnt rubber as well"---Do NOT see this at all---Yes color will be dark as stated above---But for "burnt rubber" to get to the master it MUST travel through the ABS pumps and the ABS accumulator. There are valves which are VERY small and I do not see CHUNKS of rubber going this far ESPECIALLY if the system was LOCKED---Locked means NO fluid travel.
Now, you do have "no pedal"---but that does not mean that you have a BAD master. I can put a NEW master on your car and have AIR in the system and you would have the same problem---no pedal.
I STILL question this and so do others---The ABS pumps and valves would have clogged first with this rubber.
We still need to find WHAT caused this to happen---If e-brake is out, then what? If you or the mechanic does NOT answer this, you may be buying all these parts AGAIN........
Let us know---Jimmy
No seals (burned out) on the rear calipers is going to = no pedal. Plain and simple.
