Old Dec 29, 2012 | 12:17 PM
Mrmiata's Avatar
Mrmiata
Default Re: TPMS Low pressure setting
OK, Page 216 of the 08 owners manual has a rather large box bold typed "CAUTION!" in the left hand 'column'. In the box it describes (kinda ambiguously) the TPMS ans the light in the dash. Last sentence states The vehicle needs to be driven above 20mph in order for the TPMS to receive the information. In totality, the cautionary statement leads you to believe the tire will transmit (with a nominal system) when the wheel is (going) the equiv of 20 mph or above. So, is the manual not descriptive enough? I'll now delve into the service manual and come back!
Just go let the air out of one of your tires and then check it for a TPMS indicator.. should remove all doubts..
And here's another tidbit.. TPMS indication with colder weather.. WHILE PARKED adding about 4 psi to each tire the indicator went off..
