Old Dec 31, 2012 | 10:24 PM
32krazy!'s Avatar
32krazy!
Default Re: Question about lug bolts..
Over the decades of my own tire rotations and wheel cleaning/tire cleaning, I have used one staple of a healthy lifestyle. Good ole Vaseline. I put a dab on the top few threads of a lug bolt (in the case of the XF) and for decades, the studs. After running the lugs in to the end, I back em back out and take any excess off. Until about the late 80's, I never torqued lugnuts. Ever since using the Vaseline on the studs, I have never had rust or any type of corrosion. After acquiring the torque wrench around the 1990 timeframe, I have torqued the lugnuts and recently, the XF lug bolts. In the last @ 3 1/2 years with the XF, I again used the vasi and torqued the bolts. No rust, no problems. I believe the vasi does a combination of two things after application. Normal evaporation (if you could call it that) over a period of time, and accelerated evaporation (when the wheels/rotors heat up from use). I make dang sure there is not enough to contaminate the pads/rotors and its never been a concern or problem. The super clean non rusting easily removable and installed lugnuts and lately, lug bolts are the result.
use stainless steel or titanium lugbolts and you will never have to lube your bolts again!
