Old Jan 1, 2013 | 04:10 PM
MRogers's Avatar
MRogers
Default Need some help with the airbag system
I'm rebuilding a collision damaged 2005 SRT6 roadster (light front end damage). I also bought a 2004 coupe (light rear end damage) for parts.
Yesterday I removed my dash cover from the SRT6 and removed the blown airbag. I also removed the good dash cover from my parts car and removed the airbag. I reinstalled the airbag in the SRT6 and plugged in the electrical connection. I also fitted the good dash cover on the SRT6 and started to secure it back in. The battery is still disconnected.
Is there an airbag control module that I need to swap out as well? If so, where is it located? Does it need to be reprogrammed? If so, would that be through the OBDII connection? Am I okay to make the battery connection now?
Do you have any information or experience replacing airbags?
Thanks much, Mark
