Old Jan 3, 2013 | 07:38 PM
GraphiteGhost
Default Re: Sea Foam: How to
Two things to point out! It is much harder to do the throttle body portion because of the throttle-by-wire of our engines. The second thing is make sure your careful and not pour too much too soon into the brake vac hose. Liquid in a cylinder is very costly to fix if you try to compress any liquid anything in a cylinder. Too much and you'll either blow the heads off or blow the bottom out of a (or more than one) cylinder. Peace out!
