ibedoughboy
I have a "stutter" in mine as well. It is very noticeable if you are flat cruising under light throttle and hit a bump. After the bump it will feel like it slightly misfires for a couple seconds then is back to normal. If you floor it during the stutter it takes off like nothing is wrong. One time it had a big misfire/ stutter and the check engine light flashed for a second then went out and was fine for the rest of the drive. There aren't any stored codes. Is this similar to your problem Minster?
Mine is a N/A 6 speed with 82000 miles. It has a new CPS (not a Bosch, however). I have not inspected the RCM yet, but that will come while it's down for the winter. What would be a likely culprit? Fuel filter, Bad RCM solder joint, ....?
Bad connection somewhere. This will be quite hard to trace as it is the nature of intermittent connection problems are the bane of any competent troubleshooter. Most just throw parts at it until they either give up, get sued, or magically fix it by process of elimination!
