Old Jan 7, 2013 | 04:00 PM
onehundred80
Default Re: Common SRT Belt Throwing Problems
Originally Posted by waldig
180, please note that the length of the snout is different from the stock pulley, i.e. too long. This caused the pulley to be out of alignment with the other belt pulleys and thus jump. I used the level to align the faces and grooves of the pulleys, the snout was off by about 0.200inch as shown by the rule on the top. I have been there and done that, sadly. Woody Enjoy
Woody, please note that I said your picture did not show the problem. The picture is too small and dark anyway.
RMADERMANs picture shows the inner ends lined up and you can see the error in mismatch.
I know that the snout as you call it is too long but your picture only shows that the overall length is longer. The overall length could be longer but the distance from the rear of the pulley to the ribs has to be correct.
