Old Jan 8, 2013 | 10:14 PM
grip grip's Avatar
grip grip
Default Re: Purchased new wheels, huge offsets, suggestions welcome.
Originally Posted by velociabstract
As far as the suspension bolt, with a 255/35/18 ET30 and 2.4º negative camber I have enough room. I had to roll the front fenders a little. A 245 is a perfect fit with a 30 offset.
Les
Thanks. I'm going to buy a few cheap 5mm spacers from a local autoparts store and see how it works out. I will just be using them to find the correct amount of offset. Then I'll order the hub centric 66.6 spacers.
So, 20mm on the front will move it out to a 30ET and clear the bolt. That's good to hear and is pretty much what Steve said.
As for the rear, you've got me a little confused. if you're rubbing on the inside, wouldn't you want less offset (lower number)? You're rubbing at 25, so wouldn't 28 move the wheel 3mm more toward the carrier? Maybe I should move that wheel out to a 20ET (add a 20mm spacer)?
This stuff is confusing me.
Thanks for the link.
