Old Jan 10, 2013 | 04:44 PM
onehundred80
Default Re: Crankshaft Sensor Again???
Originally Posted by hornfan10
HERE I AM AGAIN,, AT A LOCAL SHOP BOUGHT ANOTHER NEW BOSCH CRANK SENSOR STILL NO START WILL TURN OVER NO FIRE GOOD FUEL PRESSURE ,ITS JUST NOT GETTING ANY FIRE ,COULD IT BE THE SO CALLED SKREEM MODULE (CALLED THAT BECAUSE IT MAKES YOU WANT TO SCREAM CAUSE CAR WONT START) I AM AT MY WITS END
I think the common symptom of the SKREEM module failure is that it will allow you to try three times and then in will not turn over again until the battery is disconnected and reconnected. It also might run but stop running, I'm not sure on that though.
Have you tried the cam shaft position sensor? It is more expensive and I think a code would have been set though.
You say you have fuel pressure, so I am assuming you are OK there with the pump and fuel filter.
Do you know if there is a spark? There was a tool that you put by the ignition cable that lit up when the plug sparked, others just put the plug on the block and watched for a spark.
Last edited by onehundred80; Jan 10, 2013 at 05:18 PM. Reason: Mrmiata (Sherlock) noticed a typo.
