Crankshaft Sensor Again???
Old Dec 20, 2012 | 03:08 PM
hornfan10's Avatar
Default Re: Crankshaft Sensor Again???
well new crank sensor didnt fix ,relay control repaired didnt fix , ran scanner on it no codes , fuel pressure was checked also ,, it just dont get any fire will turn over but will not fire guess last thing is ecm ----- at a loss guess it time for her to ride a flatbed to dealer---------THX TO ALL THAT HAVE TREID TO HELP MERRY CHRISTMAS MY FORUM GURU'S
Old Jan 10, 2013 | 04:28 PM
hornfan10's Avatar
HERE I AM AGAIN,, AT A LOCAL SHOP BOUGHT ANOTHER NEW BOSCH CRANK SENSOR STILL NO START WILL TURN OVER NO FIRE GOOD FUEL PRESSURE ,ITS JUST NOT GETTING ANY FIRE ,COULD IT BE THE SO CALLED SKREEM MODULE (CALLED THAT BECAUSE IT MAKES YOU WANT TO SCREAM CAUSE CAR WONT START) I AM AT MY WITS END
Old Jan 10, 2013 | 04:44 PM
I think the common symptom of the SKREEM module failure is that it will allow you to try three times and then in will not turn over again until the battery is disconnected and reconnected. It also might run but stop running, I'm not sure on that though.
Have you tried the cam shaft position sensor? It is more expensive and I think a code would have been set though.
You say you have fuel pressure, so I am assuming you are OK there with the pump and fuel filter.
Do you know if there is a spark? There was a tool that you put by the ignition cable that lit up when the plug sparked, others just put the plug on the block and watched for a spark.
Last edited by onehundred80; Jan 10, 2013 at 05:18 PM. Reason: Mrmiata (Sherlock) noticed a typo.
Old Jan 10, 2013 | 05:13 PM
Mrmiata's Avatar
180.. you are correct on the Skreem symptoms.. but I think you mean cam sensor?
And remeber.. John had no code on his SRT6 when he was at Krazy32's with it..
Old Jan 10, 2013 | 05:19 PM
Thanks Sherlock, I fixed the typo.
Old Jan 20, 2013 | 04:35 PM
jetdriverk's Avatar
Any solution yet?
roar
Jun 15, 2022 11:46 AM
rampntlion
21
Feb 11, 2019 08:18 AM
caseydeankopp
Sep 13, 2015 07:25 PM
bobbie
Sep 12, 2015 12:49 PM
2004_
Sep 4, 2015 01:39 PM
