Old Jan 12, 2013 | 01:58 PM
pizzaguy
Default Re: Key in ignition for the glovebox lamp to work?
Ok, time to publish the mod.
First, go to AutoZone or Walmart and get ya two of these:
They look like this, but wont' have the fuses installed:
Now, take the two of them, strip the ends of the wires and, using a crimp connector and tool, splice them like this:
I know you can't read the fuse ratings, but using their colors, you'll know what fuses to put in there.
You will need only a 20 amp and a 15 amp fuse, the OTHER 15 amp and the 10 amp are already in your car and
you will install them in the following step.
Now, cut the one blade off from the one fuseholder - use diagonal cutters or whatever, but MAKE SURE YOU CUT THIS BLADE!
Now, go to the car and remove the cover from the fuse box on the driver's side. Remove fuses 16 and 31 and use them to populate
your home-built harness. Install the harness as below - the dual fusholder with one blade missing is installed on the left, in position 31.
YOU MUST POSITION THE HOLDERS WITH THE RED WIRES "UP" toward the center of the car.
YOU MUST CUT THE BLADE OFF OF THE ASSEMBLY ON THE LEFT as directed above.
The Yellow fuse holder and it's wires are not part of this mod - ignore it!
