Old Jan 13, 2013 | 11:27 PM
onehundred80
Default Re: Shift Bezel keeps popping up, fix?
Originally Posted by Scott_lmtd
Thanks guys for the replies.
Pizzaguy- yes, thats it, wth the window buttons. Double sided tape is not a bad idea, need to look at the clearance.
closer9- yeah, its in there correctly. I've had it on and off a number of times, routing wires and such, so I think the plastic tabs are probably weak. There is a metal bar the helps keep the console tied together, that cab be slightly adjusted back and forth with the two screws, but it hasn't help me. When you say broken, do you mean the tabs underneath are broken off?
I have just recently put that part on and the metal bar at the back can be moved a little but not much, the forward part of the cover plate hooks under it, the two latches at the back of it snap under the forward part of the rear console. It may not snap too well if either part has been rounded over.
If anything is rounded over you may be able to put some epoxy on the part and rebuild the sharp corners by filing the epoxy to a square shape. Rough up the plastic before applying any epoxy and let the epoxy set for a couple of days before attaching the plate again.
