Scott_lmtd
Thanks guys for the replies.
Pizzaguy- yes, thats it, wth the window buttons. Double sided tape is not a bad idea, need to look at the clearance.
closer9- yeah, its in there correctly. I've had it on and off a number of times, routing wires and such, so I think the plastic tabs are probably weak. There is a metal bar the helps keep the console tied together, that cab be slightly adjusted back and forth with the two screws, but it hasn't help me. When you say broken, do you mean the tabs underneath are broken off?
The tabs are fine, but the "ring" is broken on each side. Two places actually on the driver's side. I just made sure they all kind lined up, and snapped in, and never have any trouble with it. I figure one of these days I may upgrade the boot, and have been looking for a nicer leather **** with no numbers.
