Windsheild spray nozzle?
Jan 14, 2013 | 11:35 AM
20
permalink
onehundred80
Apr 2006
25,432
648
Ontario
Re: Windsheild spray nozzle?
Quote:
tonygg
+1 I'll try and remember to use them this coming spring...I think the fluid is over four years old in the tank!
I picked my car in Florida and found that on the way home the light indicating a low fluid level flickered for a few hours and then stayed on, I filled up the tank and it still stayed on.
Later I took the tank out and discovered that it must have been filled with just water regularly as there was a large mass of slime inside that had jammed the fluid level float resulting in the light staying on.
This slime was also in the hoses and nozzles, I had to clean them all out and this was all it needed, I had thought the float needed replacing.
My point is that you should not use plain water as the tank turns into a biology experiment pretty rapidly and the slime blocks hoses and nozzles, some slime could be seen hanging out of the nozzles in my case.
I'm sure Canadians and those in the North do not use water in the winter, but could use only water to add to the tank in the summer, I'd caution against that.
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
