Old Jan 14, 2013 | 11:56 AM
ala_xfire
Default Re: Windsheild spray nozzle?
I picked my car in Florida and found that on the way home the light indicating a low fluid level flickered for a few hours and then stayed on, I filled up the tank and it still stayed on.
Later I took the tank out and discovered that it must have been filled with just water regularly as there was a large mass of slime inside that had jammed the fluid level float resulting in the light staying on.
This slime was also in the hoses and nozzles, I had to clean them all out and this was all it needed, I had thought the float needed replacing.
My point is that you should not use plain water as the tank turns into a biology experiment pretty rapidly and the slime blocks hoses and nozzles, some slime could be seen hanging out of the nozzles in my case.
I'm sure Canadians and those in the North do not use water in the winter, but could use only water to add to the tank in the summer, I'd caution against that.
Yea 180, "AIN'T NOBODY GOT TIME FOR THAT ! "
