Re: How much is it to replace a intercooling pump on srt?
The pump is about $125 plus install, if you have access to a wrench head, its a 2 hour Job to jack up, pull wheel, wheel house cover, fluid, hoses, connect wires, swap pump and reinstall and bleed air out. If it new to you could be twice that time, not hard just turn the crank sorta work. For one that has done it once, its easier to do another. Enjoy Woody
Need to post your area...
