Old Jan 16, 2013 | 11:51 AM
RL67037's Avatar
RL67037
Default Re: Crossfire some times not starting
Originally Posted by exshankerz
Hey just having a problem with my crossfire and wondering if anyone has had the same experience with my problem cold start the engine is fine! I have done some research but it does not seem to tick any boxes 100% to what I am having. Say I drive up the street turn it off then restart the engine it may not kick over the starter engine sounds fine I can hear the injectors clicking the Battery is brand new , driving there is no backfiring so the spark plugs are fine and also new that I think also rules out for the fuel pump due to no back firing correct me if I'm wrong it has also stalled a few times just turned off when to a stop mabye it could be the fuel filter? Also the engine light comes on if it does not start I have recently bought a code scanner still in the mail I might try that first before I take it to a mechanic , it's is a 2004 model limited with 80k miles so there could be a few things needing to be replaced I would love some input to what this problem be even a bad sensor over heating issue? The engine temp is normal radiator is at normal levels that's all I can think of to give you guys a idea what the proble could be , I was driving it quite hard when I first encountered the problem. Thanks
Have you checked the solder joints on the RCM? Get a magnifying glass because you may not see the cracks with the naked eye (I sure didn't).
https://www.crossfireforum.org/forum...-no-start.html
RL
