Old Jan 21, 2013 | 10:55 AM
ala_xfire
Default Re: Pulled the plugs
Originally Posted by csteve0355
I'm looking to pull my plugs for the first time, and with the tight space - what should I use for tools to get the wire cover off and plugs out?
An open end wrench that just fits in the small part of the cover works pretty well, use the valve cover as a leverage point.
If you then remove the coil packs, it is a lot easier to access the plugs.
( NOTE: The 'A' wire goes to the front plug of each pair )
