Re: Water pump failure?
I did it three times, the bolts are different bolt lengths, color them and use a cardboard templet to plug the bolts into. I used the new pump housing to mark the holes in the cardboard, then stuffed bolts in as I pulled them.
There is one on bottom that is hidden, beware. SRT is different from NA beware. About 3 hours first time. Rob can get you one.
I did a posting on it once, should be searchable.
Enjoy, Woody
