cmberges
That's what I needed to know (BOOM). I knew there was something there just never thought of the gas tank until now and it makes sense. Guess the subs are going in the rear. So if I replace the front speakers with some, say, infinity kappas or something would it be better to run them off the deck power with x-over box (included) or off the factory amp (x-over box or no box?) and then just use my deck pre-out to run a mono-amp and subs in the rear?
OR
A 4chan amp to run the fronts and subs and leave the factory stuff alone?
Personally, if you do not have the equipment already, I would go the route I went with my last car - sounded amazing. I replaced the front set and rear subs all with Kappa components, and ran them off a 4 channel and a monoblock for the sub amp. Since you have a roadster and space is limited, I would get a nice 5 channel (4 channel + 1 sub, typically like a 75x4 + 150x1) or something similar and replace the factory amp, all the speakers, and add a nice single 10" or 12" driver in the trunk. Should be PLENTY of volume for top down cruises...
Just my $0.02
