Old Jan 23, 2013 | 07:25 AM
onehundred80
Default Re: Need help with a rear driver side suspension squeak AND a question about SRT6 bra
Originally Posted by Kolme
Ok, first is the squeak issue. Over the past couple of months, a progressive squeak has formed around the rear driver side wheel. The squeak now occurs when driving with minimal to light bumps and is absent with harder bumps. When parked, the squeak can be reproduced by applying a moderate amount of force on the rear driver side of the car. I checked to ensure that the parking brake had nothing to do with the squeak (as noted in other threads). Overall, the squeak sounds terrible and i cant take it anymore!! ahhh!! So if anyone has some insight on this issue for our cars, please let me know (especially if you have any advice with a low budget attached, just spent a little under 2 grand on the car this winter due to an unlucky radiator resevoir leak, accident, and Skreem module malfunction).
Second, I need a little help in making sure I have the right front brakes for my car (2005 SRT6). Using partstrain.com I found both my rotors (which i know are correct due to the specs) and my brakes (what im a little worried about).... The brakes I bought are Akebono EUR682. Akebono EUR682 EURO Ultra-Premium Ceramic Brake Pad Set : Amazon.com : Automotive. I'm a superrr novice when it comes to brakes (and most things it seems), and noticed these brakes have a "two prong" bracket on the back of them as opposed to "one pronged" brackets. Soooo, did I make a goof in trusting partstrain.com or am I spazing over nothing?
Thanks tons for your help, these issues have added on additional stress to an already stressful month
The noise could be the rear stabilizer in the bushings. There is a lot of stuff moving around back there though. It's best you get a friend help you pin point the problem.
Here is a pad for the SRT6, I have Akebonos and they are OK pads with little dust.
This is not an Akebono pad though.
