aschrager
I just found out where the 5th O ring goes. The oil filter cap unscrews from the shaft that the filter goes on. If you unscrew it you will see it. I was also told that if the shaft isn't loose. Leave it alone. Don't replace the O ring if the shaft isn't loose.
Woooooooo Hooooooooo, so the final answer is; It is for the cap/shaft where it screws together (but don't replace if it is not loose)...
Mucho-appreciatio!
GREAT FIND!
