Old Jan 23, 2013 | 04:01 PM
Larry Hitze's Avatar
Larry Hitze
Default Re: Mann Filter...5th O-Ring?
Originally Posted by aschrager
I just found out where the 5th O ring goes. The oil filter cap unscrews from the shaft that the filter goes on. If you unscrew it you will see it. I was also told that if the shaft isn't loose. Leave it alone. Don't replace the O ring if the shaft isn't loose.
I wondered
