Old Jan 27, 2013 | 04:36 PM
pizzaguy
Default Re: Pulse Module - WHERE IS IT?
If it is there it may be a bridge box (or a spare). The definition of a 'Bridge Box' that I use would be to hold a connector, or have an internal set of jumpers to 'bridge' wiring as in a terminal box.... I take it (since I do not have a standard) that the manuals do not have the 'turn key, release' and it continues to crank until starting, feature?
Originally Posted by MoparFreak69
You are correct. On a 6 speed car, when you release they key the starter disengages, whether the engine is running or not.
Hence, I believe the "Pulse Module" in a 6 speed is just a jumper from the line coming from the keyswitch to the line going to the starter relay/solenoid. Going to tear into mine in a few minutes and find out!
