crossfirewannabe2
$ 386 to replace/install lower left and right ball joints ?
$ 575 to replace/install right upper control arm ?
$ 275 EGR valve with solenoid assembley (part only)
$ 177 install new EGR assembly and clean EGR tube ?
shop rate $88.69
chicago,illinois
Not sure about the ball joints but the EGR valve can / should be able to be purchase for between $100 and $150. To replace it ............you could probably do it yourself. Just did one on my other care and it was 2 bolts and a gasket. Took about 10 minutes.
Good luck.
