Old Feb 6, 2013 | 01:06 AM
Dementors's Avatar
Dementors
Default Re: Noisy Wavetrac - Am I the only one???
Jesse, doing this on a daily driver would be tough but I think four weeks would be on the long end of the time frame. Devin at Unitrax was able to turn mine around in one or two days. If you give him the heads up that you are sending it, he should be able to give you a quick turnaround.
Shipping from Louisiana cost about $85 Fedex ground with a shipping weight of 73.80 lbs. I used a very small but thick cardboard box. Make sure to drain the oil out before shipping.
Unitrax with the first group buy was charging about $200 for the install plus shipping. Not sure if that has changed.
I included a couple of links below providing more information.
https://www.crossfireforum.org/forum/tsbs-how-articles/49823-srt6-rear-end-removal-short-cuts-2.html
In this link, I summarized much of the discussion about the Wavetrac. You will see farther down that I was corrected on a few of my comments but all in all it is a good starting point.
https://www.crossfireforum.org/forum/crossfire-srt6/43476-needed-20-pre-order-wavetrac-lsd-slk32-srt-6-a-57.html
Good luck!
