Old Feb 8, 2013 | 05:57 PM
  #62 (permalink)
pct's Avatar
pct
Default Re: Hi all! Prospective Crossfire owner
Originally Posted by Uk Pete
Spent an hour today removing all the crud from the 'ledge' under the rear wheel arches. It was well packed in so glad to get it cleaned out. Can anyone suggest a product to help prevent corrosion in these sort of areas?
Hi Pete i've just done the de-crudding of my rear arches too, once i'd dug them out I gave them a scrub around with a piece of that green plastic pan scourer stuff, then I soaked a piece of rag with some thick gloopy 90w gear oil which i happened to have lying around in the garage and applied a good layer into the inner ledge, i did two applications giving each one about 15 minutes to soak in, then finished off with a handful of grease (wearing those condom gloves) and gave that a good smear around leaving about half an inch of it around the inner ledge.
Its a good idea to stick a couple of carrier bags or rags over the tops of the rear tyres while you do it, but I escaped with just a few random drips.
Ongoing i'll scoop the grease out out and re-apply some fresh stuff every year and hopefully that should look after those area's.
