Old Feb 12, 2013 | 01:46 PM
ala_xfire
Default Re: Flat Towing my 2003 Automatic Trans Xfre
Originally Posted by kenkaiser
I have a motor couch & I would like to know what I have to do/modify to tow my Crossfire that has the automatic transmission with 4 tires on the ground [flat tow]. Will a trans fluid electrice fluid pump work? Is a drive shaft disconnect available?
KK
Something like this :
Carry-On Tandem Axle Utility Trailer Located at TrailersPlus Lebanon - 4YMUA1624DG009596
Would probably be the best option .....
1. You don't put any wear on the car's tires.
2. You don't have to modify the car in any way.
3. Easy on/off.
4. You can use the trailer for other purposes when not using it for the car.
5. It has electric brakes on one of the axles.
