Flat Towing my 2003 Automatic Trans Xfre
Old Feb 12, 2013 | 01:29 PM
kenkaiser's Avatar
Default Flat Towing my 2003 Automatic Trans Xfre
I have a motor couch & I would like to know what I have to do/modify to tow my Crossfire that has the automatic transmission with 4 tires on the ground [flat tow]. Will a trans fluid electrice fluid pump work? Is a drive shaft disconnect available?
KK
Old Feb 12, 2013 | 01:46 PM
Default Re: Flat Towing my 2003 Automatic Trans Xfre
KK
Something like this :
Carry-On Tandem Axle Utility Trailer Located at TrailersPlus Lebanon - 4YMUA1624DG009596
Would probably be the best option .....
1. You don't put any wear on the car's tires.
2. You don't have to modify the car in any way.
3. Easy on/off.
4. You can use the trailer for other purposes when not using it for the car.
5. It has electric brakes on one of the axles.
Old Feb 13, 2013 | 01:34 AM
loosecannonxf's Avatar
Smile Re: Flat Towing my 2003 Automatic Trans Xfre
Blue Ox has a baseplate listed under "2005 Chrysler Crossfire". Remco has the transmission lube device for either the N/A or SRT 6 automatics. 6 Speed manual equipped cars do not need a driveshaft disconnect. In many states you will also need a braking assist device like Brake Buddy. I've been towing my xf for almost 5 years and, despite some members predictions of doom and gloom, the sun still rises in the East every morning. Google is your friend. Good Luck and Happy Motoring.
Old Feb 14, 2013 | 11:10 AM
Many states require a brake on ALL axles on a trailer. You should check with each state your traveling through!
franklindm
Mar 14, 2020 12:23 PM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
rfourt
Sep 25, 2015 01:38 PM
Den656
Sep 23, 2015 12:27 PM
Vegaslegal
Sep 10, 2015 11:24 AM
