onehundred80
I guess you attached the door catch cable to the white plastic connector on the inside of the door panel correctly?
I attached it from the top and pushed down. But when I pull the door handle it does not fully disengage the door. Almost as if there is some slack in the cable. I am getting this in both doors, something that did not happen until I took the panels off. Any suggestions?
