onehundred80
When you pull the door release handle do you have a few inches of free play in it before it releases the door?
I am trying to think what it looks like when it is together, I believe the outer cable is stopped from moving while the door handle just pulls the inner wire cable. It has been a while since I did it.
I did not see an inner and outer cable, just one cable. And there is no play before the door releases, the door simply is not releasing unless I push on it after pulling the handle. It is as if the handle needs more room to pull the cable
