Old Feb 17, 2013 | 10:07 AM
onehundred80
Default Re: Door Panel Help Please!!
Originally Posted by SrWilliams
I get what ypu are saying but it would appear that your cable would get twisted up in a knot and creating problems. I understand your concept but it does not appear the mechanism was made to be twisted like that. Kind of scare me. Has anyone else done what Orlando suggests. If so, then maybe I will try twisting up the cord
Slow down and think about this problem with reason, you took it apart, never touched the lock mechanism. When you went to put it together it was not working. Now what does that tell you? It tells me you are putting it together wrongly.
I would assume that Orlando put his together wrong as well, but he decided he could fix it by doing what he said you should do.
If you want to do that then go ahead, and I will not bother to say another word.
As I said you are putting it together wrong as I did before I realized, within less than a minute, what I was doing was wrong.
The angled wire clip fits in the white plastic snap more than one way if I recall correctly. You do not have to attach the door panel to check it, just drop it over the top of the door and the door release and check to see if it works.
