If I'm following the pics in this thread correctly, I need to move this pulley, that is on the alternator mount bolt, up to the blank hole in the water pump. Does that sound/look correct? This is a 75mm C3 replacement pulley, if I remember correctly.
Also one note: if you have the $50 replacement tensioner:
https://www.crossfireforum.org/forum...placement.html)
You may need one extra washer behind the new idler, otherwise it idler will rub. No big deal, just figured I'd mention it.
