Old Feb 19, 2013 | 06:38 PM
  #58 (permalink)
latemodel21's Avatar
latemodel21
Default
Originally Posted by Buggin
If I'm following the pics in this thread correctly, I need to move this pulley, that is on the alternator mount bolt, up to the blank hole in the water pump. Does that sound/look correct? This is a 75mm C3 replacement pulley, if I remember correctly.
Also one note: if you have the $50 replacement tensioner:
(https://www.crossfireforum.org/forum...placement.html)
You may need one extra washer behind the new idler, otherwise it idler will rub. No big deal, just figured I'd mention it.
yes you are correct it is that hole shown with the arrow.
I was not aware of the other tensioner if you tell me the washer I will supply it with all future tensioner pulleys
Thanks
Chris
