Old Feb 21, 2013 | 04:34 PM
  #527 (permalink)
cmz's Avatar
cmz
Default re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
just did this mod . great write up. a little trick i learned,you can pull the main electrical plug off the back of the ignition switch assy. after the assy is removed. there is plenty of slack in the wiring harness. with the ign. assy still mounted theres not much room too get the harness plug off the back of the switch. cmz
