Old Feb 22, 2013 | 08:14 PM
onehundred80
Default Re: strange things happening
Originally Posted by janaiy
but I haven't replied in private and if you go ahead and look at the previous mmessages I already said thank you for the help I received previously. So 180's message might be for the other guy , but not for me.
I think I can include you, your last post before today was when you were stranded with battery issues on November 20th. You replied after my post here and said you had changed the battery and it had solved the issue.
Hi, yes, I bought a new battery (but mine was old) and all strange things did not accur anymore. If you have strange things happen, check your battery or if its not an old battery, than clean the battery where they get attached to give power (sorry don't know the name for it). Another issue could be water related. Check the forum for that. Another problem I was told here is the RCM, again check the forum, there are many threads with pictures about this issue. I hope this helps.
First check the simple things like battery and than go from there. I would not go to the Dealership because these guys have no clue and you pay lots of money!!!
I hope this helps.
You had three months to answer your previous post and you did not and now your shorts are in a knot.
This was the post three months ago.
Re: need new Battery/ Autocraft Gold H6 48 is this Battery good for my XF 06 roadster limited? I am stranded and can't find only this one at advanced auto parts
By sheer chance I was the first to answer that post within 20 minutes of you posting it and told you that the battery was OK, I never got a thanks or for that matter a PM.
My reply.
H6 and 48 are good numbers for our batteries, the only thing to check is the height as some require a spacer under the clamp. Other than that you are good to go especially in an emergency.
